1010 HYDRAULIC PROBELM
SHAWN HUDSON
02-24-2006 19:58:05
HELP, THE 3pt HITCH JUMPS UP AND DOWN (SURGING). THOUGHT THAT IT MAY HAVE AIR IN THE SYSTEM BUT DRAINED AND REFILLED AND STILL DOING IT. ANY IDEAS?
buickanddeere
02-26-2006 03:40:36
 Re: 1010 HYDRAULIC PROBELM in reply to SHAWN HUDSON, 02-24-2006 19:58:05
Up to serial number 42,000 the rockshaft/remote hydraulics on a 1010 are identical to the later 330,430,435 & 440. As previously stated she just needs cleaning and calibration after 40+ years of work around mud, manure, moisture and no oil changes.
sam dubs
02-25-2006 14:41:55
I am thinking about buying a 1010. I was told "they were queer". by one guy and another guy said he seems to recall head problems. He said something about the 1010 being the first model after the put puts and the next model John Deere got it right.
What is the story. Was it a good tractor? Did it have live PTO?
Com,ments will be appreciated.
buickanddeere
02-25-2006 19:11:00
 Re: 1010 HYDRAULIC PROBELM in reply to sam dubs, 02-25-2006 14:41:55
Any 1010 gasser is fine and the last year of 2010 gasser production was ok. As for your adviser's twisted s*xual preferences? I suggest you never leave anybody alone with him or turn your back on him.
Loren NC
02-25-2006 15:04:00
You might want to do a search on this site for 1010 and read some old posts. Those of us who have them think they do what we need or I guess we wouldn't keep them. However, the world in general thinks they are pretty bad. Perhaps a sample of that opinion came from my dealer who said they almost bankrupted John Deere and that the only thing worse than one with a gas motor was one with a diesel motor. My dealer also refuses to work on the hydraulic system of a 1010.
Loren NC
02-25-2006 13:45:06
I am going to repeat some advice I got on this site back in 2002 from a fellow called Guy when I posted a problem about my 1010 hydraulics. He emailed me a diagram from a repair manual, so this detail won't mean much to you unless you can get a manual. I didn't ever go ahead and try this, but if it works, the fix sounds simple. Email me at lworley@statesville dot net if you want me to share a very old email address for Guy with you. Here is what he said:
"Mine did the same thing and mine only needed a 25 cent shim. In the diagram below there are 2 check valves, and when my hyd jerked up and down I could hear the side that was bad. I drained the hyd fluid and popped the snap ring (X) out. Then with a needle nose plier I pulled everything out (which was real easy) until I got to the shim (P). Then I put everything back in the way I took it out and put the hyd fluid back in, and it's been running great. P.S. there are different hyd systems on the 1010 so make sure you get the right part number."
Even though it sounded easy, I never did go ahead and try it. Let me know if you want to try to reach Guy by his old email address. Could be if you get a picture of a dual hydraulic system labeled "Tractors, 1000 Series--Hydraulic Systems" you could figure out what he was talking about from just reading this and looking at the picture. Good luck.
JD@Antique Acres
02-25-2006 07:59:56
Still might have air in the system. Try to bleed off
