Broken Mag Screws
Mixman
02-24-2006 19:35:18
I was given a X Wico mag just to see if there was anything I could do with it. It was froze up but I got it loose and somewhat cleaned up. The problem is there are 2 cap screws broken off in the housing below flush. Any suggestions??
430WLPG
02-25-2006 17:26:35
 Re: Broken Mag Screws in reply to Mixman, 02-24-2006 19:35:18
I had one like that as it had one of the screws that held the points in broke off flush. I've always had good luck welding a nut to it. I did this many times with no luck,So I tried one more thing,I put that little housing in my huge milling machine and I was working with a 8-32 screw, anyway I drilled a small hole about a 3/64 through the center of the screw,Then welded a 10-32 nut to it one more time and it came out like a champ,So it can be do.
Mike M
02-25-2006 05:14:00
Find someone with a milling machine to drill them out with an end mill as they don't wander off.
Glen in TX
02-24-2006 21:09:48
Small left hand drill bits and small ez-out for the #8 screws and patience and luck. May have to drill them out and put in heli coils. New XH housings are available. If it's the screws holding laminations in housing leave them alone! The screws on back side holding impulse ring are special thread. #12-28 I believe.
