1020 charging
machinery-man
02-24-2006 18:35:02
Previous post I spoke of light remaining on but trying to dim upon rpm increase. One of the responses advised to replace diode on alternator which I did plus replacing brushes. This made no change. I am wondering if my regulator is also bad? Cannot see any shorts or problem with wiring. With key off I get voltage to one side of the alternator, with key on voltage to both sides. Any advise appreciated.
machinery-man
02-24-2006 20:24:22
 Re: 1020 charging in reply to machinery-man, 02-24-2006 18:35:02
I have the remote regulator and is on firewall...also I replaced the isolation diode....
jdemaris
02-24-2006 20:00:28
As the other guy told you, a diode will do it, all it takes is one to keep the light dim. Delcos are particularly known for getting one bad leg in the internal diode-trio. Do you still have the original Motorola, and if so, does it have the piggy-back regulator or a remote-mount regulator?
Bob
02-24-2006 19:41:46
I suggested checking the (rectifier) diodes INSIDE the alternator. I sounds like you replaced the isolation diode, mounted on the back of the alternator.
You need to get inside the alternator, and check the 6 diodes in there, and the stator.
