JD 1941 A PTO Problem
Greg F
02-24-2006 16:51:53
I have had some trouble in the past with my power trol moving the rock-shaft. I got that fixed. Found out the idler gear was missing from the hydraulic pump. Well things were working fine for a few months and then I notice a noise when I engaged the PTO. Sort of a whine. I decided not to use it till I could get the pump back apart to take a look. I drained the oil from the power trol and hydraulic pump area and loosened the bolts up. I pulled the PTO shaft / hydraulic pump cover, gears and all straight back and away from the tractor. I have a plug I use to keep the gear oil from running out. I could find nothing wrong by looks. I started fishing around the oil ports and at the drain hole I dug out a piece of metal. It sort of looks like a cotter key type thing. If you want a picture let me know and I will be glad to email it to you. I figured this could be the noise. This metal just touching a gear. I put everything back together and now the PTO shaft will not spin. It engages ok and the lever moves fine but will not turn when the clutch is engaged. I can turn the PTO shaft by hand just fine. I now think this piece of metal may be important�LOL. If any of you have any ideas on where to start I would appreciate it. The manuals I have do not cover this real well. Thanks for any help you can give.
Shpwreck
johns48b
02-26-2006 06:18:39
 Re: JD 1941 A PTO Problem in reply to Greg F, 02-24-2006 16:51:53
sounds like you just didn't get it put back together correctly if everything was working before you took it apart. don't go looking for other problems until your sure you got it put back togther right.
Mike M
02-25-2006 05:20:44
Alot of those whine for a little bit when first started until cycled a few times to get the oil flowing.
That piece of metal was not helping rubbing in there either.I think your problem lies in that the coupling that hooks the pto shaft together ahead of where you took it apart fell off when the back part was pulled out.
36 A
02-24-2006 17:58:42
Greg I"ve got a 1943 A all tore down and i went and looked .It was a cotter key and it goes through the fork .It"s about 4" up from the floor on the pto lever.Just take the cover off one key,one gasket and that should do it.HOLD ON I just went and looked and with the bull gears in (there not in mine )if you go in the rear or the trans cover you better have a thin arm!GOOD luck 36 A
Greg F
02-25-2006 06:17:09
 Re: JD 1941 A PTO Problem in reply to 36 A, 02-24-2006 17:58:42
Thanks for the fast help....so I need to take the PTO engage lever cover off?? or do I try and come from the rear forward?? I am sure this is not going to be easy. I have a parts manual if you can direct me to a page via part numbers. Thanks again.
Greg
