D2628R wheel weights fit what?
R-fan
02-23-2006 19:05:07
I bought an International 240U to repair and sell. It had a set of John Deere D2628R wheel weights on it. What model tractor do they fit? They are nothing like the weights on my 60 or my R. Thanks
Duane Larson
02-24-2006 06:22:44
 Re: D2628R wheel weights fit what? in reply to R-fan, 02-23-2006 19:05:07
R-fan,
The D2628R was introduced in 1940 and served as the inner wheel weight (the one closest to the wheel, not inside the wheel) for (most) all rubber-tired wheels on letter series tractors. Bolt sets were available to attach to spoke, cast, and pressed steel wheels.
AD984 was used if additional outer weights, bolted on over the D2628R, were needed and it was replaced about 1948 by the D2183R outer weight.
Duane Larson
02-24-2006 08:34:53
 Re: D2628R wheel weights fit what? in reply to Duane Larson, 02-24-2006 06:22:44
Glen,
I don't have either, so I am just "going by the book" in this case. The Price Lists give a description of the weights, and the D2628R is listed as the "inner" weight and the D2183R is listed as an "outer" weight, which replaced the AD984 "outer" weight. A picture I have of a F&H DP2628 shows it over a 5-bolt hub clamp, however. So apparently it could be used as either the inner or outer weight. I suspect the problem came when putting weights on the old F&H round spoke wheels, some of which had larger center hubs than others and the "inner" weight, with a larger hole, had real meaning.
Glen in TX
02-24-2006 09:15:48
 Re: D2628R wheel weights fit what? in reply to Duane Larson, 02-24-2006 08:34:53
Ok thanks Duane, I just wondered and will have to look in my pile of weights later and maybe I'll take some pics too. Not sure if I have any with the D2183R number. On this pic of D we put 2 F&H DP2628 weights on outside and wanted to keep the width down for trailer fenders yet more weight than the smaller one and we had to grind down the outside diameter of the first outside weight to make it fit. On inside we had one set of D2628R mounted.
Duane Larson
02-24-2006 10:55:54
 Re: D2628R wheel weights fit what? in reply to Glen in TX, 02-24-2006 09:15:48
Thanks for the nice pix, Glen - good looking D. I'd be interested in knowing anything you learn, and if there is any difference between the DP2628 and the D2628R.
Glen in TX
02-24-2006 22:18:32
 Re: D2628R wheel weights fit what? in reply to Duane Larson, 02-24-2006 10:55:54
Duane, I put several pics of D2628R weight and F&H DP2628 on parts and pieces gallery. I'm not sure what these weigh but probably close to the same, 70-80 lbs.?? The JD D2628R is about 18.5" O.D. and F&H DP2628 is about 23" O.D. You can see how they fit together with the smaller OD D2628R as a inner weight. I don't have any of the D2183R or AD984 weights and didn't see any at big auction today.
Duane Larson
02-25-2006 07:44:28
 Re: D2628R wheel weights fit what? in reply to Glen in TX, 02-24-2006 22:18:32
Thanks, Glen! Great pix of the weights. Any listings I have of the weights all show between 135 and 140 lbs for the D2628R, probably depending on whether the attaching bolts are included. The D2183R is listed at 137 lbs. I wonder if F&H cast the D2183R part number for Deere, and called it F&H DP2628 weight? It wouldn't be the first time a Deere p/n and a F&H casting number don't agree. Or maybe there are D2183R weights out there - I haven't looked hard but I have seen many more DP2628 than D2183R.
Glen in TX
02-25-2006 20:50:59
 Re: D2628R wheel weights fit what? in reply to Duane Larson, 02-25-2006 07:44:28
They don't seem to weight that much but maybe so? I don't have scales anymore to find out. Yeah both having the 2628 on them yet looking different made me wonder how close in weight they are? The D2628R is quite a bit thicker than F&H weight. The true JD weights are more rounded on the edges and cleaner looking too than other foundry weights and the F&H ones.
Glen in TX
02-24-2006 07:00:27
Duane, So is AD984 the same as F&H DP2628 ? We only have the F&H in larger outer ones. Thanks.
Glen in TX
02-23-2006 22:45:06
I know they will fit rear axle of AR, H, & D and probably several other letter series tractors. It's about 18" OD. They will bolt on the inside and outside of AR or D as a starter weight and then a larger F&H DP2628 weight (20-23" ?) will will bolt over the top of them or can just stack the smaller D2628R. I have some that look the same as D2628R but don't have a JD no. or any foundry marks or nos. on them also.
