12v/ electronic ignition conversions for 1950 JD B
elcajonfarms
02-23-2006 17:41:42
I've been thinking about converting my 6v to 12v and going to electronic ignition--I have one of the late B's with a distributor instead of a magneto. Would like to hear from anyone who has done either conversion on a late styled A or B, and what your experience has been. This tractor has been awfully hard to start and it needs a new battery, so if it make sense to switch I'd like to do it now.
gold-leaf- deere
02-25-2006 17:50:28
 Re: 12v/ electronic ignition conversions for 1950 in reply to elcajonfarms, 02-23-2006 17:41:42
I have ran five 4230 gas tractors, I have installed Dennys Electronic in two of them and it did not help them at all, still foul plugs after 5 to 6 hours, did not help the hard starting when cold, recently bought a electronic kit from Brillman for my 620 gas, I have not installed though after the 4230 troubles
buckeye al
02-24-2006 14:40:11
I too find myself agreeing with Mike. Any time our '51 gas B would not start after just a few revolutions it was time to start checking things! Back in the 60's Ohio regularly had cold snowy winters and everything had just 6 volt batteries. If anything would start in the whole neighborhood it was our B with the delco distributor and the neighbors 51 all fuel B with the Wico X series mag.
I recall watching the neighbor's son pull vehicle after vehicle with the B in -20 real air temp weather. They had a heat houser & we didn't so we let 'em go for it!
I'm not against electonic ignition or saying what you have in mind is a bad idea. I'm just relating that all the late B's I've been around were about as easy to start as an electric motor with a cord already properly wired! I suspect therefore something is wrong that MAY not be solved by the proposed conversion!
RedJD
02-23-2006 21:44:34
Check your ignition timing if its off it will be hard to start.
DSK
02-23-2006 19:48:32
Machinery Man is right. The electronicignitions can do nothing but improve the reliabilty and performance of your tractor. Tell me why anyone wouldn't want an ignition system that is impervious to water, dust and heat and is hidden under the stock cap. Electronic ignition is the best thing that ever happened to these tractors.
Farmerboy
02-23-2006 19:28:54
I agree with Mike - 6 volt is plenty for a B. My 1950 B has never failed to start on 6V even with an el cheapo car battery from Farm and Fleet. A tune up and a battery with the highest CCAs you can find will be considerably cheaper and a lot easier. Do you open the petcocks when starting? That will let it crank a lot easier.
B-maniac
02-23-2006 19:27:18
Have to agree with Mike,if all else is in good shape and tuned up you will never know whether it's electronic or not by the way it runs and starts. Everybody says to change the old muscle cars over also. My '66 GTO showed no change whatsoever. Electronics do have their place,but it's not on old muscle cars or old tractors....save your money or put it toward a higher quallity paint and rest. job. It will be better spent and WILL make a difference.
Mike M
02-23-2006 18:51:50
Do you have a wico or delco dist. ???
No reason what-so-ever that this model is hard to start on 6 V other than it needs properly tuned up and/or overhauled. That electronic ignition may help cover up for other problems.
machinery-man
02-23-2006 18:33:20
I can"t say enough about electronic ignition, it solves tons of problems. On your set up you need a later model distributor, delco as on 50"s. Then switch over to 12 volts, lights, generator, install hi capacity coil( I use genesee products and Andy can properly advise. You"ll have the most ignition available and good starts.
