1010 wiring help
Loren NC
02-23-2006 14:16:10
I posted a while back about replacing the ignition switch in my 1010. Next time I drove it, I noticed that the temp gauge no longer registers correctly. Never got above about 140 as long as I drove it, whereas it normally runs up close to 200. What could I have done in plugging in wires to the ignition that would have changed the way it reads?
jdemaris
02-23-2006 17:40:17
 Re: 1010 wiring help in reply to Loren NC, 02-23-2006 14:16:10
Correct me if I'm wrong, but didn't all the 1010s use mechanical temperature gauges, i.e. no electricity used? Maybe you've got an aftermarket gauge of some sort?
Loren NC
02-24-2006 16:16:08
 Re: 1010 wiring help in reply to jdemaris, 02-23-2006 17:40:17
Interesting question for which I have no answer. Perhaps mine is aftermarket. I just know the needle acts differently with the key turned on or off, so it has to be electric.
jdemaris
02-24-2006 20:10:34
 Re: 1010 wiring help in reply to Loren NC, 02-24-2006 16:16:08
I don't recall ever seeing any Deere tractor of that vintage with an electric engine temp. gauge. I only have a 1010 crawler parts book, not for ag. tractors so I can't look it up. My 1010 crawler is mechanical, and my 1020 ag. tractor is mechancial. If it's Deere, it will look like a Deere gauge. Anyway, most cheap aftermarket electric gauges are pretty simple. Full power from the ignition switch to one side of the gauge, and the other goes to the sending unit on the engine. The unit sends a ground signal to the gauge, the hotter the engine, the more ground. To do a quick check, you just ground the wire hooked to the sending unit, with the igntion on, and the temp. gauge should go to full hot. When the wire is unhooked, the gauge should go to full cold. When the ignition switch is off, and there is no power getting to the gauge - different makes react different ways - some go to hot, some to cold, and some to the middle. More expensive gauges including many used in cars and trucks, do not run on full system voltage. Instead, there is usually a small voltage regulator that, lets say in a 12 volt systems, feeds 7 volts to the gauges - sometimes including the fuel gauge as well as the temp. This way, a steady voltage is assured to the gauges no matter what else is going on in the charging circuit.
Loren NC
02-25-2006 13:49:06
 Re: 1010 wiring help in reply to jdemaris, 02-24-2006 20:10:34
Thanks. I will try grounding it and see what happens.
