1010 Row Crop Distributor
LumbrJakMan
02-23-2006 13:53:30
Hello, I have a Buddy who is Looking for some Tips on Getting a bit more UMMPH outta his 1010 Row Crop. Any tricks he can do to his Distributor to get a bit more Ponies ?? We pull with a club and they are all tweeking there Tractors so we are just tryin to keep up.
Thanks ....
jdemaris
02-23-2006 17:50:25
 Re: 1010 Row Crop Distributor in reply to LumbrJakMan, 02-23-2006 13:53:30
The 1010 four cylinder gas engine is basically the same size as a 420 two-cylinder engine, one has four little cylinders and other two big ones, so I wouldn't expect too much out it. I don't believe you're going to gain any power increase by updating the distributor unless part of your plan is running at higher RPMs than standard and raising the compression ratio. Once you start doing that, I'd be nervous about the reliability, it is not a very heavy built engine. I've heard of a few people using 1010 diesel blocks, putting 2010 gas-engine heads on them (and pistons and other parts) and then having a heavier gas engine with the extra main-bearings. But, with the little 115 cubic inch 1010 ? ? I'd have more faith in the 113 cubic inch 420, it was built better.
Loren NC
02-23-2006 14:06:56
Are you trying to keep it original? I have heard several people here talking about going to electronic ignitions and have considered it for my 1010 because of all the slop there is in the distributor shaft.
LumbrJakMan
02-23-2006 14:16:58
 Re: 1010 Row Crop Distributor in reply to Loren NC, 02-23-2006 14:06:56
Hi Loren, No it doesnt have to be original. I have Electronic in my Farmalls and its a sweet set up. Starts on 2nd crank almost every time. And if its Damp still fires right up. I am Looking more into a Little Trick others may use or tips for fine tuning .....
