J-D 70 clutch repair
Big Al's Acres
02-23-2006 11:23:55
It is getting close to spring farming and I need to work over the clutch in my 70 J-D. I would guess that the repair is rather straight forward. Would one of you fellows, with more experience than I, drop a note and tell me what to look for, specific weaknesses, easiest or best methods, replace all or just the friction disks, proper setting when complete with repair, etc.?
Thanks, Alan
buckeye al
02-24-2006 14:57:05
 Re: J-D 70 clutch repair in reply to Big Al's Acres, 02-23-2006 11:23:55
As for the parts, I just go to my very friendly and extremely capable Deere Dealer! I call 'em first & if they don't have it, they soon will.
As for baling.... Pushed many many bales of hay & straw out of a 24T baler with my 70D & live PTO.
Once had some youngsters get a bit cocky about the speed we were running which was about 15 strokes per bale. They were rather energetic & bragging of their abilities so at one end I clutched, throttled back & slipped the range shifter up to high (2nd gear) which is a good step on a 70 and engaged the clutch without ever slowing down.
The hay was perfect for baling and it tied one off every 8 or 9 strokes. They got real quiet & kept up but after that round I went back to low & never heard another peep from the wagon!
Big Al's Acres
02-23-2006 15:51:23
From our experience on this forum, where is the best location to purchase the two clutch disks and also the drive disk if wear dictates, (also springs)? Is it bad to squirt a bit of heat at the adjusting nuts to get them to move? My tractor is a good strong runner that has not been abused and as such I bet the last clutch adjustment was done in the 60's. I have not been able to put the cover on and plan to install when I am done with this clutch job. By the way, I bale all my hay in small bales and prefer the J-D 70 over my newer tractor. I like the low end torque and sitting up in the saddle higher so I can see over the baler. I, also, do not like running the baler at the given RPM to just beat the devil out of all the rotating parts. I can push out a very good quality 85 lb. bale at 2/3's PTO speed, and in good hay, with the J-D 70 and not lug her at all.
Al
buckeye al
02-23-2006 14:27:40
Only thing I'd add to what Blksmok says would be to be sure the springs that push the outer plate away from the pulley when in the disengaged position are good and strong. You might be surprised if you compare one in the tractor to a new one! They are what disengage the pack when you pull back on the clutch lever. If they're weak, the tractor will tend to keep right on marching after you yell whoa! Been there. Didn't like it much either!
While all the guts are out & while you're this close, I'd remove the pulley (or at least slide it out on the crank 'till it hits the tire) so that I could grease the heads of the toggles and clean & pack the pulley's roller bearing. I've had good luck with a full synthetic wheelbearing grease. Stays put, stands up to high temp & makes a substantial difference in how smoothly the clutch operates.
This was probly last done in the 60's!
Blksmok
02-23-2006 12:18:36
Big Al...assuming the operating sleeve, dogs, toggles and bearings (all the internal parts)are ok, just pull the clutch pack out and closely inspect the friction plate behind the clutch driver, the clutch driver, the sliding friction plates and the sliding metal plates for wear. The friction plates (2) can be cracked or worn thin, the clutch driver (1) can have wear on the teeth that drive the sliding metal plates (2). The sliding metal plates will show wear as sharpened or broken teeth where they mesh with the clutch driver. The sliding friction plates(2)could have delamination of the friction material or thin friction material. If the clutch adjusting bolt ends protrude beyond the edge of the pulley housing to the point where you cannot install a clutch cover, you have internal wear inside the clutch assembly.
mjbrown
02-23-2006 14:01:27
 Re: J-D 70 clutch repair in reply to Blksmok, 02-23-2006 12:18:36
My 730D has that problem with the bolt heads protruding too far to get the cover on. I have been through the clutch trying to find out why and replaced nearly everything to no avail. Can you be specific about what is worn to cause this. The clutch doesn't make the clunk going in but does coming out.
sgtbull
02-23-2006 16:51:22
 Re: J-D 70 clutch repair in reply to mjbrown, 02-23-2006 14:01:27
For MJBROWN. I'd look at the dogs inside the clutch. They are cast iron, and the three operating bolts ride in a fork cast in them. The problem is likely that the socket portion of the dog, where the toggle goes (a steel piece that has a mushroom shaped head on each end), wears, allowing the dog to "tilt" more, and the bolts stick out further. The toggles will wear too, but they are made of hardened steel and having compared new ones to well used ones, it appeared they don't wear much. The dogs are are simple to replace, after you remove the pulley, but they are about $40 each. Replacing them will also make your clutch "snap" in and out very satisfactorily. I've replaced them on several tractors I've had over the yrs and that always makes a dramatic improvement.
