4010 longevity
rboulware
02-23-2006 09:59:29
It is ONLY fair to pose the same question to the deere guys as I have to the Allis chalmers group. I found a 4010 with a rebuilt engine (so the seller says) I have no REASON to doubt the seller on this. Any way if I was to take real good care of the tractor and change the fluid and filters on schedual what is the Maximum amount of hours should I see on this engine before I do a rebuild? It is a diesel by the way..
rboulware
02-24-2006 06:51:12
 Re: 4010 longevity in reply to rboulware, 02-23-2006 09:59:29
I think I failed to say that the rebuild was done at a dealer ship..
txgrn
02-24-2006 06:41:45
Mother Deere has a bottle of conditioner, reasonably priced, that is designed to solve the corrosion problem associated with wet sleeves. But it still doesn't hurt to change coolant if you can.
Mark
Jim in AK
02-24-2006 01:03:37
I had my 4010 rebuilt 5 or 6 years ago still have all the receipts and photo also. Ask to see some paper work on that "rebuild". Like a canceled check or check with the person that did the work. If a rebuild was really done there should be some paper of some kind on it some where.
Jim
DSK
02-23-2006 11:03:50
If the overhaul was done properly and completely, you should be able to get 5000hrs.+ out of a 4010 major. One of the most overlooked maintenance items on these wet sleeve engines is coolant replacement. It should be replaced every 3 yrs. Many a JD 404,466 motor has had its' life shortened by broken down coolant. This causes cavitation which erodes the outside of the sleeves to the point that eventually the o-rings at the bottom of the sleeve fail. Diligent maintanance includes a coolant replacement schedule. This applies to all color wet sleeve engines.
Greg H. WV
02-23-2006 10:29:36
As far as the longevity of the overhaul, it really depends upon how professional the job. However if it were me, I would ask the guy to see the receipts from the rebuild kit to see what all was replaced. When I rebuilt my 4020, and had head work done ect. I kept all the reciepts to the tune of over 1700 and that was seven years ago. That way atleast you will know what was put in the tractor. Later Greg H.
