70 D live pto conversion
fred stillger
02-23-2006 09:36:35
I have a 70 D parts tractor with live power and want to convert my 70D with transmission driven pto. Any problems making this conversion?
John Deere 70 owner
02-24-2006 09:00:40
 Re: 70 D live pto conversion in reply to fred stillger, 02-23-2006 09:36:35
I too was wondering about doing this on a JD 70 all fuel tractor I own without live power...it would eb a lot of work...but make the tractor more usable...I dont know about a tractor with non-live being worth more though? Is that true or does it only apply to the diesels?
Thanks!
fred stillger
02-24-2006 19:21:56
 Re: 70 D live pto conversion in reply to John Deere 70 owner, 02-24-2006 09:00:40
I would think any tractor with live pto would be worth more not less. I am not sure what he break down is between 70's with and without.
fred stillger
02-23-2006 20:54:22
Thanks for the comments. Good food for thought.
I have all the part books and manuals. I will start by converting the power steering systems.
I may try the pto later.
deerechaser
02-23-2006 11:17:12
just think about it this way as I do with my 70d. how rare is it with no live power?
Blksmok
02-23-2006 10:25:47
Fred....big,big project. You should consider selling your 70D and the 70D parts tractor and buy one with live pto, unless your 70D's have sentimental value.
DSK
02-23-2006 10:22:32
You may want to consider the magnitude of this project before you start on it. You will have to disassemble your transmission, first reduction and change the entire rear housing assembly on your good tractor, and install the live PTO parts from the parts tractor. Not saying it can't be done, but plan on spending about 35 to 50 hours to complete it. It will also cost you about $200-300 for gaskets seals & oil. It could cost alot more if you find bad parts in either unit.
Mike M
02-23-2006 10:00:50
Sounds like you should have all the parts. It's just going to take about total disassembly of both tractors to make the swap. Get ahold of a shop manual and a parts book.
