GLEN IN TEXAS.........LP HELP
TEXASJ
02-22-2006 19:16:57
How do i remove the j and s reg/vaporizer out of the manifold??? does it come out the front or do i have to take the manifold off and push it out the back? thanks.
430WLPG
02-23-2006 17:21:58
 Re: GLEN IN TEXAS.........LP HELP in reply to TEXASJ, 02-22-2006 19:16:57
The vaporizer has a bolt with a clamp on each side that holds it in . Just remove the clamps a take a heal bar and pry in the slots and after a little trouble it should come out. You don't have remove the manifold. It has a o-ring for a seal.Is it leaking? They do get eat up and will leak fuel into the coolant.
TEXASJ
02-24-2006 17:52:56
 Re: GLEN IN TEXAS.........LP HELP in reply to 430WLPG, 02-23-2006 17:21:58
Thanks for the replies. it is froae up. the middle section does not move. need to remove to exam it. thanks again guys.
Glen in TX
02-22-2006 21:30:01
Well, I'm not real sure? Never worked on a J&S but have done Zenith and Impco. You might contact your local LP guys again or the bunch at R&W. They didn't seem to know too much about J&S when I asked before and neither did others here local. Had a pic of a J&S setup on a D but lost it off old puter. Most of those other ones are either threaded into the manifold with a o-ring seal or held with a snap ring or screws.
www.impco.ws/
