HELP PLEASE-Reduction gear
Mike Treasure
02-22-2006 14:17:29
On my John Deere 70 I have a noise in the reduction gear going down a hill-no noise going up.OK I tore into it today,the clutch bearings all look good -one friction disk is broke.What I did find was the reduction gear slides around on it's shaft.Pushed in it works good but when pulled back it grinds on the housing.The bearings seem good.Can I shim it to stay in?Any ideas?Thanks again,Mike
DSK
02-22-2006 18:13:25
 Re: HELP PLEASE-Reduction gear in reply to Mike Treasure, 02-22-2006 14:17:29
I think you must be talking about the inner bearing as you mentioned a snap ring, the bearing that sits in the main case bore. This is the one I was hoping wasn't bad. Unless someone else knows a shortcut, the only way to remove this bearing is to remove the entire transmission top {sliding gear} shaft. The input shaft can then be slid into the case and removed with the pressed on bearing attached. There is also a bearing pressed inside the input shaft itself where it supports the right end of the sliding gear shaft. It would be a good idea to replace this bearing anyway along with the bearing in the first reduction cover. I hope the bad bearings were what was causing your noise and not busted gear teeth, but you'll see this when you take out the top tranny shaft. Yes, its somewhat of a job, but take your time, consult your shop manuel often and remember experience is the best teacher.
DSK
02-22-2006 14:50:03
I would assume you have not removed the first reduction gear cover.[large cover under pulley]. The condition you are describing is certainly not normal, and pulling that cover might reveal the obvious cause. Itcould be a bad bearing on the transmission input shaft, or it could be a missing spacer under the outer bearing. I remember a case where an aspiring young mechanic forgot to replace this spacer after he supposedly overhauled the transmission on an A.Does your tractor have a live PTO? If it does not, there should be a large spacer behind the first reduction gear also. Although the bearings might feel OK when you spin the gear, it doesn't mean they're good. More than likely you've got a bearing problem, keep us posted.
Mike Treasure
02-22-2006 17:08:28
 Re: HELP PLEASE-Reduction gear in reply to DSK, 02-22-2006 14:50:03
I took the large gear cover off and your right the transmission imput shaft bearing is out.I got the snap ring off and now cannot get the &^%$# bearing to come out.Would that have been my cluncking noise?Any ideas here?Thanks again,Mike
jd b puller
02-22-2006 18:20:20
 Re: HELP PLEASE-Reduction gear in reply to Mike Treasure, 02-22-2006 17:08:28
Mike, you ever use a can opener on a can of green beans and drop the lid down in the can? Now pull it out without touching the sides. Can't do it. Unless someone has a shortcut, I think you'll be pulling the side cover (where the belt pulley is. Yee ha! Oh, and the bearing will stick to the 1st reduction gear so you won't be able to get the cover off. Make yourself a "pusher" with a piece of 3" channel. Drill 2 holes in it to put a bolt thru where the little button cap goes. Push the shaft in by tightening the bolts. This will in turn pull the bearing off the shaft.
