4020 power steer problem - need advice
yellercat
02-22-2006 11:44:04
Having a problem with the steering on the 4020 and looking for assistance. The power steering works , but the front tires sometimes lag the motion of the steering wheel. That is to say I can turn the steer wheel and the front tires are slow to respond to the full effect of the turn. Condition has come on slowly and seems more noticable when hydraulic use is heavy , as when baling. Sometimes it even feels as if the steering wheel hits an immovable object for a bit and then will go ahead and make the desired revolution. Anybody had this particular symptom, would like to know what you found out?? tanks yellercat
yellercat
02-24-2006 11:03:24
 Re: 4020 power steer problem - need advice in reply to yellercat, 02-22-2006 11:44:04
Thanks for all the ideas you guys. Feeling that it is something to do with the steering system after listening to your ideas. I use the hyd system heavily with bale accumulator and hyd baler and front loader. Those items have been working properly last time used. Will ck pressure and continue from there. yellerc@
donmyeil
02-23-2006 05:34:55
9 times out of 10 the steering motor seals are worn out. when you turn to the right do the wheels slowly turn when you hold the steering wheel in a right turn? this is an indication they are worn out. Also you can remove the small hose (abt 3/16 hose)on the top of the oil cooler,plug the oil cooler ,start the engine and turn the steering wheel like you were cultivating corn and trying to stay on the row. there should be very little oil coming out of that hose if more than a few drops then the steering motor seals are worn out. hope this helps Don
yellercat
02-23-2006 05:42:46
 Re: 4020 power steer problem - need advice in reply to donmyeil, 02-23-2006 05:34:55
Don, yes that is what seems to be happening. Almost like a delayed reaction of the front wheels turning. Sounds like you have had some experience with this situation. Thanks for the reply, I will check it out as you explained. thanks again, yellercat
ET
02-22-2006 12:43:18
The first thing to do is to bleed the steering system. If that does not help you may be developing an internal high pressure leak in the steering valve.
yellercat
02-22-2006 12:48:15
 Re: 4020 power steer problem - need advice in reply to ET, 02-22-2006 12:43:18
Steering valve, is that part of the hyd pump? Thinking not, can you advise where it is located? thatnks
ET
02-23-2006 07:04:19
 Re: 4020 power steer problem - need advice in reply to yellercat, 02-22-2006 12:48:15
The steering valve is the bottom of the steering post under the dash. The bleed valve is on the left side of it. There are some specific steps to properly bleed it.You should get a service manuel or I&T manuel before you dig in.
Mark / Wi
02-22-2006 12:17:50
Check your transmission/hydraulic fluid. Had a similar problem with a 4010, filled it with fluid and it went away. Good luck
yellercat
02-22-2006 12:30:22
 Re: 4020 power steer problem - need advice in reply to Mark / Wi, 02-22-2006 12:17:50
Did check the fluid level, and that doesn"t seem to be the problem. Also have changed the filter and cleaned the screen. Problem persists. Thanks for the input tho.
jdemaris
02-22-2006 12:49:38
 Re: 4020 power steer problem - need advice in reply to yellercat, 02-22-2006 12:30:22
The steering valve needs a going through once in awhile, it has a lot of moving parts and also one large sealing ring on its hydraulic piston. There are two intake valves, and two outlet valves, and a set of adjustable rocker-arms that activate them. Very often the valves get leaking and the rocker-arms get loose. I used to do a lot of them, it's about and hour job once the valve is out. Of course, I'm assuming your hydraulics are working okay otherwise, and it's not just a hydraulic issue. I know some people don't use the hydraulics for anything, so don't notice problems until the steering starts to act up. Deere has the steering on a priority circuit, i.e. it is first to get oil and will starve the rest of the system if necessary to keep the steering going. Usually, when you start to have hydraulic pump problems, the tractor will crank very hard and want to eat up starter motors.
jdemaris
02-23-2006 06:53:41
 Re: 4020 power steer problem - need advice in reply to jdemaris, 02-22-2006 12:49:38
check hyd pressure, possible the tram. pump is going out.
