2010 Hydraulic Pressure
RB70D
02-22-2006 06:43:52
Thinking of getting a 3-point log splitter. Do these splitters work out well and can anyone tell me what the hydraulic pressure is on a 2010. I need 2000 psi to properly power the splitter.
Bob Clark
02-22-2006 17:36:56
 Re: 2010 Hydraulic Pressure in reply to RB70D, 02-22-2006 06:43:52
Had a 2010 in late 60's, early 70's. If the hydralics are in good shape it will be adaquate for a splitter if the cylinder is a 3 1/2 or 4 incher. The break away pressure on a 2010 is probably around 2000psi and 16 gpm I think. This will be better than an older tractor like an A or a IHC M etc but not quite as fast and powerfull as 3010 or 4010 with the piston pump (I used to use a 4010 on a splitter and it was excellent)
billde
02-22-2006 07:30:12
If the hyd system is in perfect shape it will operate a 3pt splitter. 3pt splitters are however SLOWWWW. Tractors have a hard time matching the pressure and volume of a good gas powered log splitter.
G/MAN
02-22-2006 10:25:35
 Re: 2010 Hydraulic Pressure in reply to billde, 02-22-2006 07:30:12
Smaller, older tractors at least. Take a newer tractor with 3000 psi of stall pressure and 30 gpm capability out of one remote and it's a different story.
G/MAN
02-22-2006 07:28:07
I don't have the specs in front of me, but a 2010 should have a stall pressure in that range. Then your next problem could be flow, as they don't flow a lot of oil.
