60 Heat Exchanger replacement
Bob VanWuyckhuy
02-21-2006 17:16:04
I have a model 60 with a rusted out heat exchanger. Has anyone replaced one and how big of a job is it? Where should I look for the parts besides a dealer?
Thanks
Carl NY
02-22-2006 18:22:49
 Re: 60 Heat Exchanger replacement in reply to Bob VanWuyckhuyse, 02-21-2006 17:16:04
Bob. The heat exhanger has to be placed in the manifold from the bottom as it is a tapered fit. The manifolds will have to be removed from the head to accomplish this. The bolts on the exhaust manifold are usually a problem to remove as you will probably snap one or two off. The intake bolts usually remove with ease.
DSK
02-22-2006 06:37:55
By heat exchanger,I assume you are talking about a rotted out exhaust manifold. The only practical repair would be complete manifold replacement. See topic 730 exhaust manifold replacement, posted on 2-18, the same procedures apply to your 60. KK sells a quality replacement manifold {reproduction} for around 200 bucks. {317} 398-9883
Larry in WNY
02-22-2006 09:02:22
 Re: 60 Heat Exchanger replacement in reply to DSK, 02-22-2006 06:37:55
If you go for the new manifold, coat the new heat exchanger with never seize. It's made to take heat.
