Greg H. Wv
02-21-2006 08:05:33
I had a problem with my tractor running away with itself over a month ago. I am currently in the process of taking my Gov apart, to check for worn parts, and to make sure the weights are attached properly. The manual stated that after removing the fly wheel, and backing plate, I would have access to the Gov, and be able to pull the shaft out the side, to check weights, gears and bearings ect. I removed the inspection plate, took off the conecting plate to the operating rod. Then I took out the three bolts that retain the quil, where the tack cable screws into the Gov. Then I removed the cover from the side of the gov., and attempted to remove the quil, and the stem from the gov housing, so I could pull the assembly shaft out the side of the gov housing. The problem starts here. I cannot get the quil to clear the pony motor bell housing, where the clutch assemply bolts on to it. The book An IT manual bought here stated that I should be able to accomplish a simple rebuild without removing the govenor shell, or casing as it is. Do I still have to remove the pony clutch assembly, or is the book wrong, and I need to remove the whole govenor housing, to remove the shaft? And if so god help how hard is it to get all this back together again? Thanks for any input. By the way, if you're asking yourself, is this guy mechanically stupid? The answer is yes, so now that it's been established please use small words in your explinations. Thanks Again Greg H. WV
