60 Stuck, Help needed
Bob VanWuyckhuy
02-21-2006 04:36:17
Hi, I have a JD A that has been in a shed for 10 years now.The farmer went out one spring and found it to be stuck and soaked the cylinders with oil and penetrating fluid. Now I have the job of getting it free. The cylinders are horizontal, correct? How do I get the entire cylinder soaked? I will be getting the tractor home and in my garage where I can work on it easier. Thanks for any advise or sure fire solution. Bob
jason mills
02-21-2006 10:00:23
 Re: 60 Stuck, Help needed in reply to Bob VanWuyckhuyse, 02-21-2006 04:36:17
Good luck getting them broke loose this way. I had an unstyled A that had sit for years that i restored. I tore engine apart first pulling head and then removed crankcase cover and rod caps. This will allow you to remove block with pistons and rods. Be carefull with your rods. I then put my block in a press and used a hydralic jack to push the pistons out of the block. Use a piece of steel plate close to piston size if you are going to reuse pistons to hopefully prevent damage. This worked for me as i sleeved block and rebored to fit original pistons.
Ravgardner
02-21-2006 05:08:48
Bob, sorry I had a Model on my brain. What year is the 60? Filling the compression chamber with diesel is one method. Some mechanics use penetrating oil or Marvel Mystery oil, but I think diesel is good. If it dosen't break free easily after soaking for a week or so, don't force it by hooking a chain and pulling down the drive way. Take the head off and the crank case cover off so you can work on it properly without causeing more damage than you may already have.
Ravgardner
02-21-2006 05:07:10
Bob, What year is the A? Filling the compression chamber with diesel is one method. If it is 47 or newer it will have petcocks or plugs in the bottom of the compression chamber that can be used to drain the diesel after soaking. Some mechanics use penetrating oil or Marvel Mystery oil, but I think diesel is good. If it dosen't break free easily after soaking for a week or so, don't force it by hooking a chain and pulling down the drive way. Take the head off and the crank case cover off so you can work on it properly without causeing more damage than you may already have.
