630 WHOOPS OIL BATH FROZEN!!!!!!!!!
TIMAR
02-20-2006 19:17:50
Started my 630 today, which I purchase last week while it was 64 degrees here in KS. Last 5 days our highs have been in the teens and lows below 0. It started right up but started blowing white smoke out of everything, and would not throttle up. Shut her down and went and cut a few hedgeposts to ponder what was wrong. While I was out cutting, it hit me that it must not be getting any air. Went back home to shop and took off the oil cup on the air cleaner. BINGO!! Frozen white gunk.
Well I set the cup in the sun, pulled the plugs out, dried them good, and then turn the motor over with them out to expell the oil-gas mix, and then re-installed the plugs. Now it won't fire. Could it have pulled motor oil back past the rings? Maybe the carb is plugged up now? The oil on the plugs was too clean to be out of the aircleaner. Any ideas how to get her dried back out or should I just let her set a couple days.
billde
02-21-2006 09:04:17
 Re: 630 WHOOPS OIL BATH FROZEN!!!!!!!!! in reply to TIMAR, 02-20-2006 19:17:50
Chances are when you started the tractor, because the air cleaner was over-full,it sucked a nasty oil water mix in through the carb causing (white ?) smoke. Get everything thawed out,put in a fresh set of plugs, leave the bowl off the air cleaner, give it a light shot of ether, start it up. When the exhaust is clear, free of smoke, shut it down, fill the oil cup to the proper level, put it back on and restart. It may smoke again but should clear up quickly.
The same thing happened to me this winter with 2 tractors of another color, no harm done.
B-maniac
02-20-2006 19:47:22
Seems to me that a frozen oil bath would do the same thing as closing the choke. If you shut off the air you get black smoke and it floods out and eventually stops.White smoke in a gas engine is steam. You are burning water from somewhere. Did this tractor have antifreeze in it when you brought it home to the deep freeze? If it ran good when you brought it home,I think you have more than just a frozen oil bath. Put it in a heated building for a couple days,drain the water out of everything(air filter,carb,coolant etc),then crankit over with plugs out. Put plugs in and start it up.If it runs fine then add coolant and watch for white smoke . If it does you know what your problem is.If it doesn't smoke and runs fine again then you fixed the problem.
