Coolant leak on 4320- need advice
Rodney j
02-19-2006 15:34:47
Just finished an engine overhaul on a 4320. Right away, I had coolant leaking around the engine block heater, which I had just replaced the o-ring on. Took it back out, made sure I had the the surface where the o-ring seals against the block clean, and reinstalled with another new o-ring. Now I have a much smaller leak. Anyone know a trick to get this thing sealed 100%? This is the same style of block heater used on 30 and 40 series tractors, goes in the left side of the block.
Glen in TX
02-19-2006 20:45:04
 Re: Coolant leak on 4320- need advice in reply to Rodney j, 02-19-2006 15:34:47
Make sure there are no pits in the machined area of block casting. Can fill pits with JB quick weld and sand back down. Go over the sealing area lightly sanding smooth with emory cloth and/or scotchbrite or steel wool. Silicone might work for you but I don't like it because it's makes things slide. Shouldn't need any sealer with the o-ring but might try some brush on Permatex high tack to seal it. It's sticky and stays flexible and seals antifreeze, fuels, and oils.
Magiver
02-19-2006 20:23:43
Drain the system and clean the block and heater. Then use clear silicone and let it cure or what is called skin over before reinstalling the heater in the block. Letting the silicone skin over has fixed many leaks around the thermostat area on many tractors I have worked on.
