1020 Charging system
machinery-man
02-19-2006 14:50:14
Have been restoring my 1020 diesel and wanted to put a heafy battery. The book said they used 2 420 amp battery but I got an 875 cold cranking at 0 degree. I notice that upon running the amp light is high red idling but dimms on reving up by does not go compleletely out. I checked alternatior and is cranking out 15 volts. Is this usual on the tractors. I have a 110 and light goes out. Wonder if the regulator needs replacing. I can"t see that size of battery would be a factor. Any comments appreciated.
machinery-man
02-19-2006 15:38:21
 Re: 1020 Charging system in reply to machinery-man, 02-19-2006 14:50:14
thanks Bob, will check connections, looked up parts JD parts and understand diode...noted $25.50 from Deere...thanks for advise....
Bob
02-19-2006 15:04:51
Sounds like a shorted alternator diode, or a poor (high resistance) connection in the charging circuit, somwhere between the alternator and the battery.
Using a larger battery is NOT the problem.
