JD1520 diesel blow by
jphill
02-19-2006 08:50:41
My 1502 has started to produce blow up after it warms up. Whats causing this? and how do I fix it?
Bob
02-19-2006 10:23:23
 Re: JD1520 diesel blow by in reply to jphill, 02-19-2006 08:50:41
What is commonly referred to as "blow-by" is caused by combustion products leaking past the piston rings.
This can be due to worn or broken piston ring(s) or ring grooves, or piston or sleeve damage.
If engine coolant or fuel (is your tractor gas or diesel?) is leaking into the crankcase, and boiling off as the engine warms up, that will steam out the crankcase vent, too, so start by checking to see if you oil is clan and free of coolant, and has not been thinned by fuel.
