1944 jd A oil pump
campbell
02-19-2006 08:26:48
went to start my model a yesyerday in -10c tempature,the first spin of the fly wheel didnt feel right and there was a bit of resistance as if you left the petcocks closed,anyways it did start eventually but there was a bad knock so shut her down and pulled the top engine cover to find the coupling that joins the oil pump shaft to??? was broken.there was water in the bottom of the crackcase which had froze(in the oil pump gears) and that caused the problem.is there anything else i need to check? and where could i find the square coupler? thanks cam
Dave NE IA
02-19-2006 19:44:00
 Re: 1944 jd A oil pump in reply to campbell, 02-19-2006 08:26:48
It has been several years, but I think a short chunk of 1" or 1 1/4" 14 guage or 11 guage steel square tubing is a real cheap fix. The reason I think it may be that size and guage is we have alot of scrap that size laying around. Not for sure however. Dave NE IA
JD man in SD
02-19-2006 14:39:44
I dont like the new one from deere it is to hevey i dont think it will break like old one. may take out cam gear or oil pump drive gear
will Tx.Mn.
02-19-2006 09:28:56
Wow!
Fast response!
Maark
02-19-2006 08:36:02
Usually remove the hard water and reinstall the coupler and you will be back in business. You can get a new coupler from Deere. B250R or weld the old one back together. You will need to remove the flat plate that holds the gears in place under the tractor to drop the shaft far enough to get the coupler back in place. Also replace that gasket B246R
campbell
02-19-2006 08:38:29
 Re: 1944 jd A oil pump in reply to Maark, 02-19-2006 08:36:02
ok great! thanks maark
