Hydraulics on an M
Gary north of S
02-19-2006 08:12:57
AFter two years, my 1948 "M" is almost restored. This board has been a great resource and I thank you for it. Probably my last question:
"The hydraulic line that runs from the bottom of the instrument panel back to the rockshaft housing (part #1205T) has a diagonal cut on the end that enters the rockshaft housing. There is a big nut that secures it there. There is a seal of some kind behind the nut. One of the vendors listed here sold me a new seal which resembles a 3/4" section of black garden hose. With this installed on the line, it is impossible to tighten the nut or even get it started into the rockshaft housing. What gives? Wrong seal? What is it supposed to look like, anyway? Any help sincerely appreciated as always. The part # is supposed to be M 1162 T." Gary in a frozen workwshop north of Spokane.
Henry M
02-19-2006 09:21:14
 Re: Hydraulics on an M in reply to Gary north of Spokane, 02-19-2006 08:12:57
Gary
Since you don't have the pipe instaled anyway, take the seal off the pipe and hand fit it ion the hole going into the tom and then fit up the nut. This should give you a birds eye view of room, fit in there, etc. Maybe when you put the seal on the pipe it expands it enough to keep from sliding far enough in the tom. WD 40 may help this if snug is the problem.
I would guess that is the right seal since it probably came from the same source as JD. I got mine from J|D for the 420, it slid right in and I musta had to tighten the big nud down about 1/2 inch to get the seal.
Let us know how it looks without the seal on the pipe, the seal just placed in the hole and a match up to see how the nut goes in.
02-20-2006 14:45:49
 Re: Hydraulics on an M in reply to Henry M, 02-19-2006 09:21:14
Will do so! Thanks for your prompt and helpful response. Still dubious re the seal being the right one, though.
