49b
ric in ark
02-18-2006 21:54:55
want to bring old 49b back to life , has not run sense earley 80s , any tips before try?
41JDb
02-19-2006 07:49:58
 Re: 49b in reply to ric in ark, 02-18-2006 21:54:55
Has it been just sitting or was there a reason it hasnt been run? First I would see I would see if you have spark. Get new plugs and then ground one to the frame. If you dont get spark then investigate your magneto/distributor, coil, or wires.If you do get spark drain all your fluids. Put in fresh gas and try and turn her over. Need more info to give you better help. Al
Pete/ME
02-19-2006 03:48:43
If the engine's free, drain everything, replace with new and fire it up. If it's seized break it down. It's an opinion that even if you free up a seized engine that's been sitting for a long time, running it may do some serious damage. A lot has to do with the conditions where it was stored.
