730 exhaust maniflold
piston
02-18-2006 18:37:21
need one 1959 730 gas ex. any tips on getting it loose??
DSK
02-19-2006 07:23:47
 Re: 730 exhaust maniflold in reply to piston, 02-18-2006 18:37:21
If you should happen to twist off a bolt or 2, it works to weld a nut to the broken stud, let it cool completely and rock it back & forth slowly with a wrench until you can turn it out.{it's a good idea to remove the gas tank first}. Use an eighth inch 6011 rod for good penetration.An old 2-cyl. mechanic taught me this trick many years ago. When you replace the manifold, use grade 8 bolts and torque to grade 5 specs.Remember, the threads in the head are not going to be 100% after all these years.
CH
02-19-2006 04:03:47
Email me for a manifold i will send you my link
BushogPapa
02-18-2006 20:46:22
Well, you can Pray a lot...but time is your Friend.... Soak those bolts Plenty, and DO NOT twist them off..!! Tap with a small brass hammer plenty, to loosen them where they go down thru the manifold...the Exhaust bolts are usually the worst. If you must cut the bolts, cut the HEADS off and raise the manifold as far as you can, then cut them off as High as you can, and still get the manifold off.. This leaves stubs that you can heat with a torch..(Red Hot) then tap on the end with a good rap from a hammer to loosen them. They will come right out, once you do.. I use "Never-Seize" on all manifold bolts..and on the manifold heat valve, if it is a new manifold. If the exhaust gaskets are blown, you may need to remove the head and have that surface machined or the gaskets may not hold..the metal burns away pretty fast if run a long time with them blown.. Tighten the bolts good, with the manifold HOT...really HOT...so the bolts are expanded as much as they will, and then shrink tighter when they cool... I like to match the manifold openings to the head openings while they are off..they can be miss-matched a good bit, and that will make a difference in power.. Good luck...be patient and you will get it off...!! Ron..
