Glen in TX D flywheel
Larry806
02-18-2006 15:33:32
I'm not doubting you on the nickel hole flywheel. But I have a early D parts book that shows the nickel hole till 53387. A friend has a D parts book a little newer that shows it too. I have a call in to another friend that has a older parts book just to compare. Was the D33R the replacement for the nickel hole?
Larry806
02-18-2006 18:46:08
 Re: Glen in TX D flywheel in reply to Larry806, 02-18-2006 15:33:32
Thanks guys. I understand the same number now. They also clearly have a pic of the nickel hole in both books I've looked at so far. My friends book is a 1940 & the one I have is a 36 I think. I can see them using the same pic after changing the flywheel. It would be instructing to see earlier books too
Glen in TX
02-18-2006 17:27:12
I was just going by what J.R. Hobbs has in his book JD Unstyled Letter Series. D33R is the casting number and I don't think they changed it on them? I only have a DIR108 and the D unstyled parts book PC658 (10-59) copy. Not an original copy. Post for J.R. on here or johnnypopper.com and maybe he will answer on it? JD had a program to change out the cracked spoke flywheels and nickel hole ones to the the newer style with 2" holes so many got changed over time also.
txgrn
02-18-2006 16:20:01
Glen, You never answered me.
How's the congregation doing?
Mark
Glen in TX
02-18-2006 17:52:55
 Re: Glen in TX D flywheel in reply to txgrn, 02-18-2006 16:20:01
Guess I missed your question? Email is open.
txgrn
02-18-2006 18:21:30
 Re: Glen in TX D flywheel in reply to Glen in TX, 02-18-2006 17:52:55
No biggie.
Just a jawin.
Been gone cause of my bad behavior and subsequent remourse.
Last time I was here you were a preachin. Didn't miss something did I?
Based upon that, I was just wondering how the congegration was doing?
Mark
95EB
02-18-2006 16:11:43
Glen is correct. This is one of those instances where Deere changed the design of a part, but didn't change the casting number. Somewhere in the 38XXX range, the nickle-hole flywheel was discontinued, and replaced by a flywheel with relief holes 2 inches in diameter. All of the flywheels prior to 55387 had the casting number D33R, regardless of their configuration.
