J.D. 60 power steering pump removal
Fireman
02-18-2006 11:34:41
Am trying to remove the power steering pump on my 60,need to fix fan clutches.Have done everything that the 2 cylinder mechanic at my dealer told me to do yet it won't slip out.Everything is undone,I've slid the pump forward,cut off a section of the fanshaft(1 to 5 oclock)that portrudes thru the flange so that the shaft will slip out there.Pushed the unit tight to the rad then the coupler won't dissconnect(at the same time holding the coupler rearwards as far as possible)There must be something I'm not doing right.This mechanic says he has done a lot of these and never taken the rad off to do them.If you know the trick call me toll free @1-866-741-6357
Mike M
02-20-2006 10:01:33
 Re: J.D. 60 power steering pump removal in reply to Fireman, 02-18-2006 11:34:41
I don't think I've ever had much luck with a short cut on those pumps either. It's a big job to tear everything apart and I also rebuild the pump while out too.
Larry in WNY
02-20-2006 09:35:31
To remove the power steering pump:
- Drain the coolant & remove two lower radiator bolts
- Loosen lower radiator hose clamps
- Pull radiator forward away from pump
- Unhook the linkages and fuel lines to the carb
- Unbolt the rear fuel tank support bracket near the governor
- Unbolt 2 lower dash support bolts
- Remove exhaust stack and pipe from manifold
- Remove pin from steering shaft and slide steering wheel back towards operator seat
- Use 2 bolts and mount a small chain to the hood
- Use a chain hoist to lift the hood until you have clearance to work on pump. Empty tanks are easier to work with
- If you need more room remove the air cleaner
- Remove generator and unbolt pump and hydraulic lines.
This should give enough remove to slide pump off the shaft without having to pull the hood completely off. Tilt the radiator if you need extra clearance. You should not have to cut the fan blades. Don't forget which way the fan in installed or you'll be doing this again later after it's all together again! Also, buy new friction washers and aluminum disks. If the pump is leaking save some time now and rebuild it. There's a lot of info. on this site about rebuilding the pump. Get the John Deere manual for the Power Steering system. It worth the money. Good luck.
Larry
Larry in WNY
02-21-2006 09:21:50
 Re: J.D. 60 power steering pump removal in reply to Larry in WNY, 02-20-2006 09:35:31
third party image
I almost forgot. Disconnect your oil pressure lines from the sediment bowl before lifting the hood. I'll try to post a photo from my head gasket and power steering rebuild work.
Larry
Larry in WNY
02-21-2006 09:27:24
 Re: J.D. 60 power steering pump removal in reply to Larry in WNY, 02-21-2006 09:21:50
third party image
2nd attempt at posting picture.
Link
zwr
02-19-2006 15:17:01
I know, the manual says twist the fan assembly this way or that an it'll come right out. Wouldn't for me. Move the radiator before you damage the core (like I did).
Alan Forst
02-18-2006 15:58:06
Try removing the 2 radiator mounting bolts which run through the bottom of the frame andusing a bar, you should be able to move the radiator ahead about an inch, this may be enough to disengage the coupling from the shaft. You'll have to remove the fan shroud with the fan-pump assembly. Removing the radiator completely is probably your only other option, but as long as you're this far there's not that much to it, beats tearing the radiator core. Good Luck.
