Help with part numbers
Chuck730D SE
02-18-2006 10:29:42
Anyone with a JD Master Parts Index, I need your help. I need info on the following part numbers, what they fit, etc.
820155 Washer
AF 2056 R Seal
D 2440 R Connector
A 4475 R Washer
A 1160 R Snap ring
Thanks,
Chuck
Maark
02-18-2006 11:58:07
 Re: Help with part numbers in reply to Chuck730D SE, 02-18-2006 10:29:42
Pg. 27 key 11B A1160R snap ring, unstyled A
Bob
02-18-2006 10:55:45
From JDPARTS...
AF2056R seal... OIL seal, SE (Starting engine???)water pump.
A1160R... comes up in a lot of newer (than 2 cylinder) stuff... PTO bearing snap ring in a 4010, for one app..
I will look in the MPL later, if I get my Saturday
family entertainment duties done early!
Maark
02-18-2006 10:51:46
D 2440R is an oil pump discharge pipe to case connector for a D 119100 and up, A1160R is a snapring for an unstyled A Countershaft L.H. bearing, Ser# 424025 and up and Ar 251486 and up.
Chuck730D SE
02-18-2006 10:56:08
 Re: Help with part numbers in reply to Maark, 02-18-2006 10:51:46
Thanks, any others?
Glen in TX
02-18-2006 11:33:04
 Re: Help with part numbers in reply to Chuck730D SE, 02-18-2006 10:56:08
A1160R snap ring also shows up in styled A and 60 on trans counter shaft. Not on unstyled A though.
820155 would be a Delco number and you might google it for some help also. It wasn't for a A,D or 60 though.
