#5 mower hooked to a M or MT JD
schmidtg99
02-18-2006 08:16:33
does anyone have a #5 mower hooked to a M or MT JD? I have seen one mower equipped this way. i guess i didnt realize how hard it would be to find the one part that i need to have a complete mower set up. i need the lifting rod. if someone has one i would like to make a copy of it but i need a pattern to do so. if anyone has a junk mower laying out behind the barn and has the rod that i need let me know. i can send pitures of the part that i need. any help would be appreciated thanks garrett
FDBYRD
02-19-2006 06:25:08
 Re: #5 mower hooked to a M or MT JD in reply to schmidtg99, 02-18-2006 08:16:33
I HAVE A 5FT. HOG I USE BEHIND MY M THAT WORKS GREAT. MY M HAS BEEN CONVERED TO 3 PT.
Steve Crum
02-19-2006 04:33:16
I'm not sure what lifting rod you are looking for but I have a #5 mower on my H tractor. I connected it to my M once just to see what I would need to hook it up. The qwik tach locked nicely on the M's lift bar which is locked in one position, the lift links are then removed. I made a pulley that clamped on the side of the right lift arm and ran a 3/8" cable from the lift eye on ths mower to the right lift arm on the tractor via the pulley. This set up worked real nice.
