1951 B max 3 point lift capacity
texasdeere
02-17-2006 20:32:49
I was wanting to buy a King Kutter 3-point 6.5 foot Disk Harrow for my 1951 B. The Disk weighs about 850 to 900 lbs. What is the max lift capacity of the B"s 3-point hitch? 1000 lbs?
42 B
02-18-2006 06:09:18
 Re: 1951 B max 3 point lift capacity in reply to texasdeere, 02-17-2006 20:32:49
I have a Woods 7' finish mower that I use on a "B" with a home built 3 point. The rockshaft is used to lift the mower and has no difficulty lifting the 780 lb mower. The front end does get a bit light but it works for short transport distances at slow speeds.
dave
machinery-man
02-18-2006 05:08:04
I have a king kutter and have had 4 of those B"s. You are going to max out the lift and your front will be dancing off the ground. I had a 5" bushog on my B and it wanted to bounch up hill with load lifted. The lift probably want hoist over 800-900 lbs if you"re lucky or unlocky which I hope isn"t the case. I would consider a 5" disc....or you might consider an angle frame disc...the box disc is much heavier. Good luck.
