2010 John Deere Dozer
GRainey
02-17-2006 17:29:25
Got a friend that has a 2010 J.D.Dozer and the engine has went bad,what later model engine will work in this dozer? Thanks
chubbs
02-19-2006 05:52:47
 Re: 2010 John Deere Dozer in reply to GRainey, 02-17-2006 17:29:25
hi grainey i have a 2010d with a bad reverser my be we should talk my motor is suppose to be good might think about trading or selling? chubbs
mbptractor
02-18-2006 19:43:56
i purchased A 2010 Dozer with a bad diesel motor in it. about 15 years ago if i remember right i believe i use a gas motor out of a 45 j.d .combine.
jdemaris
02-18-2006 05:51:06
Deere used the older two-cylinder engine bolt pattern for the 1010s and 2010s, so none of the next generation engines will fit. 1010, 2010, and as MSB stated, combine engines will fit. I guess you could also bolt in an older 420-430 engine if you wanted to do something weird - but it would be a little low on power. 420 two cylinder engine is just about the same cubic inches as a 1010 engine.
msb
02-17-2006 19:18:13
If its a gas engine the best alternative is to go to a combine salvage yard and find a good HC145 engine from a Deere 45 combine.Weren't very many 45 combines built with a diesel engine, but you never know, you could get lucky.Gas to a diesel or vice versa/I would not try switching from one to another.You will need to use some of the old governor linkages,water pumps, etc. since combines and tractors are different and new isn't available.
