JD 430 steering
Rusty, Mn.
02-17-2006 11:17:59
Hi to all, I took the u joint out of my 430 high crop the one under the dash, because i wanted to fix some of the play in the steering. it looks like there is some bushings bad but the yokes and the square block in the middle look ok. My ? is how do i take the u joint apart? should i try driving the four pins out from the middle, do they thread out, should i youse heat on the center block before i drive them out? I would like some insight on this before i start beating on things. they are no longer available from deere.I don`t want to break anything so i just thought i would ask. Rusty
Henry M
02-17-2006 13:08:11
 Re: JD 430 steering in reply to Rusty, Mn., 02-17-2006 11:17:59
Rusty
It sounds like you may have the shop equipment to fix it. However, I just had a thought about the wierdo U Joint that is always ragged out on the 420slant steer and your post remended me of my saga to get it squared away.
If that joint can be taken out with say a short stub on both ends and you reach an empass on rebuilding it I think there is a good chance that the man in Missouri that rebuilt my U Joint could do that one also.
I first sent him a picture of the project and later sent him the joint to fix and it came back like a new one. I don't know about the high crop but mine is never visable and as far as I was concerned it looked good enough toput on display anyway.
I can try to link you up with him if it come to that.
[email protected]
