Was just reading another thread about cans covering stacks. Made something else come to mind.I keep my tractors in a pole barn that has fiberglass insulation on the ceiling that is about 11 ft up in the air. The four cylinder tractors simply make the craft face flutter a bit, the B makes dimples in the insulation, but the D outright rips the insulation apart. Not good! As a quick fix, I took a 10" piece of round tubing and turned the OD to snugly fit into the stack. I left a small shoulder so that there would be a sealing edge against the top of the stack. Then I took a 4" diameter by 4" long piece of pipe, cut a round hole in the side of it, and welded the 10" piece of tubing perpindicularly into this hole. It somewhat resembles a "T" from the side. When operating the tractor in the barn, I slide this assembly into the stack. It weighs enough, and is long enough, that it does not shoot out even when there is a backfire. After leaving the barn, the piece comes out. It is never hot beyond what the human hand can touch, so this is easy to do. Before putting it back in the barn, the insert is again placed into the stack. Has anyone else had this problem? If so, how did you solve it? Greg
