70D---compression
oleduke
02-17-2006 09:22:55
What is the compression for the 70D big engine and how do you test it? Thanks to all who reply.
F-I-T
02-17-2006 10:44:06
 Re: 70D---compression in reply to oleduke, 02-17-2006 09:22:55
I can't recall from memory, but between 450 psi and 490 psi ought to be in the neighborhood.
To test it, you need an appropriate gauge to insert into the injector hole. Some folks have modified an old injector body to serve this purpose. Use the clamp on the cylinder head to hold it in, and use a fresh copper washer to prevent leaking.
Frank
