Breakin Rear Hub Lose
Soldner
02-15-2006 09:14:47
I am trying to break the bolts and the hub loose on a 49' JD A w/ pressed steel rims. Does anyone have any ideas how to get the bolts, and hubs loose? Thanks alot.
gtx1967jewison
02-15-2006 21:52:50
 Re: Breakin Rear Hub Lose in reply to Soldner, 02-15-2006 09:14:47
heat the area around the bolts , melt regular paraffin canning wax from the grocery store onto the bolts till too cool to melt the wax. it will wick into threads like soldering a copper pipe. let cool to room temp, I GUARANTEE the bolt will turn right out, you will be amazed. best trick i ever saw. no matter the rust or crossthreaded or what, works like magic. get it hot enough the wax flames up a little at first, then remove heat & keep waxing till no more melts. avoid heating any casting excessively or too intensely in 1 small area. always bring heat up slowly on a casting, & never cool fast.
Frank in WV
02-15-2006 19:18:50
Tom, I had to use a lot of penetrant and finally resorted to heat with acetylene torch, this plus taking off the wheel so that only the small hub was left I put a gear puller on the end and took a 3lb mini sledge to the back of the hub. Lots of raps and tighenting of the puller and finally rusty dust and movement started and the hubs eventually came off. Hope yours goes easier than these did.
Tom N OK
02-15-2006 14:21:28
You might try this site
www.retiredtractors.com/Q/rearwheels.html
Good Luck
Tom
Dan in Ohio
02-15-2006 13:27:23
Anyone tried the puller that is advertised in GM? It is pretty pricy but may be money well spent if it performs well.
Soldner
02-15-2006 12:03:01
Thanks guys! i think i'll get er now!!!
41Jdb
02-15-2006 11:03:00
Lots and lots of heat from an acetylene torch was the solution to mine!
ricedaddy
02-15-2006 10:45:29
soak your bolts in your favorite penatrant, if and when you get them loose drive the tractor around slowly and the wedges should come loose, remember slowly not in road gear!
good luck: Ron
Dave NE IA
02-15-2006 12:44:27
 Re: Breakin Rear Hub Lose in reply to ricedaddy, 02-15-2006 10:45:29
If ricedaddy's idea does not work, chain another tractor along side by the wheels, it puts alot of presure and great caution is needed by both drivers. Dave NE IA
