JD 4000 -- carb solenoid question
parrothead
02-15-2006 07:39:07
It seems that the solenoid gizmo on the bottom of the carb is giving dad some headaches. The tractor is a 4000 gas. What the heck is this thing and is there a way to bypass it somehow?
Bob
02-15-2006 08:19:03
 Re: JD 4000 -- carb solenoid question in reply to parrothead, 02-15-2006 07:39:07
To add to what Glen said, the solenoid's purpose is to instantly close off the main jet when the ignition is switched "OFF".
Closing off the supply of gasoline to the engine when the spark is shut off prevents "dieseling"... engine "run on" or backfiring upon shutdown, especially with a HOT engine.
If you decide to replace the solenoid with a mixture screw, or a plug, and backfiring is a problem at shutdown, it will help to let the engine idle and cool down a bit, before switching the key "OFF".
Glen in TX
02-15-2006 07:48:48
If it's the one with a needle sticking out on it you'll have to keep it or compare in JD parts books and might find a manual adjustable needle assembly that will screw in to work depending on which carb you have. Other solenoids have a jet and no needle or jet and needle and sometimes there is just crud in the jet and just needs cleaning with some aerosol carb cleaner. If keeping solenoid also make sure if it had a spacer gasket washer you use that.
