Brake drum removal
Elk Hunter
02-15-2006 03:18:18
I want to pull the left brake drum on my 51 A. Does anyone know, after I remove the 3 bolts and pull away from the tractor how many inches it comes out before it's free. I have fenders on and hope I don't have to pull them off just to remove the brake drum. Also, I can't tell from the shop manual how many pieces come out. Is it hard to put back in? Thanks, -T
ol' guy
02-16-2006 05:45:19
 Re: Brake drum removal in reply to Elk Hunter, 02-15-2006 03:18:18
I just measured it! You need 6 in. of free space to remove the brake assy.(Just happen to be working on mine in the garage). I had to remove the upper/inner axle housing stud for the drum to clear, so depending on how your fenders are mounted, you may have to remove them. Good luck!
41JDb
02-15-2006 07:30:02
It doesnt pull out too far only enough to get the gear out. You wont have to pull the fender. It comes out as one piece.
jdtruble
02-15-2006 03:52:56
it should be in one part, and comes straight out about 10 inches.
F-I-T
02-15-2006 06:43:51
 Re: Brake drum removal in reply to jdtruble, 02-15-2006 03:52:56
I'm just guessing, but it has to come out the length of the shoulder (3" to 4", then the width of the gear (2"), then the nut on the shaft (1"). I'm guessing it's around 7", but 10" could be just as valid.
Frank
