Clutch guestion on 48 A
Green Pulline
02-15-2006 02:07:50
I just got a 1948 A tractor that I use for pulling. Last weekend was the first time to run this tractor and I noticed a lot of the other hand clutch guys would take the tractor out of gear and engage the clutch while they were sitting there waiting for their turn. Is this something I should be doing? Thanks in advance for any help given on this topic.
Green Pulling
02-16-2006 05:11:13
 Re: Clutch guestion on 48 A in reply to Green Pulline, 02-15-2006 02:07:50
Thanks for all the very useful information. I will be sure to do this from now on. Again I really appreciate the information.
Lee B
02-16-2006 00:00:40
The real reason the clutch should be turning is to return the right main bearing engine oil to the oil sump. If the clutch doesn't turn, some of that oil collects in the transmission input gear cover case low on the right side, maybe a gallon of it. Then when you do move, all that oil tries to fit thru a finger sized hole under the clutch and some of it may blow onto the clutch disks when it all doesn't fit back into the engine sump. In addition to making a royal mess of things, your clutch will likely slip a bit at this point until you can get it burnt off.
I'm guessing maybe a half hour of idling with the clutch disengaged would be needed (more?) to actually fill that case as not all of the right main bearing oil would be slung over there, but a small fraction constantly is. After a couple of minutes it's probably a good idea to get that clutch rolling again if you are not doing anything else but waiting.
gtx1967jewison
02-15-2006 22:01:43
all the owners manuals say NEVER let the engine run without clutch engaged for long periods, any more than is necessary for gear selection, etc.
Frank in WV
02-15-2006 19:22:14
As Mike M said yes it saves wear and tear on the clutch. Also keeps it cooler so it doesn't get hot and slip. Put her in neutral and let the pulley turn by engaging the clutch.
Mike M
02-15-2006 04:43:04
Yes. That helps save wear and tear on the clutch disks and pulley bearing.
