Am I crazy or what: 4630 JD
Mark Westphal
02-14-2006 20:06:15
I can buy a 4630 with only 2400 original hours with a powershift tranny and 3 remotes. He wants 17500 for it. I need at least 130 HP to run a big square baler. I would really like a 4440 but around here they are going for 21K or above for over 7000 hours. A 4440 has much better resale but my question is: Is the price for the 4630 too much or is it in the ballpark for actual hours?
Thanks,
Mark
mark Westphal
02-15-2006 07:49:16
 Re: Am I crazy or what: 4630 JD in reply to Mark Westphal, 02-14-2006 20:06:15
I have found out that the tractor is a 1977. It has had new starter, new radiator and consistent servicing over its life. I only need 1000 pto with this baler and I would not use it in winter. I have a newer tractor for winter use.
Thanks for all of your help,
Mark
JDBert
02-15-2006 06:08:39
A 4630 is heavier and will out run a 4440 in the field ALL day long. Like mentioned earlier they only have 1000 pto BUT its the small one. Transmission would be the same as a 4440 PS. If it gets cold where your at the 4630 (404-turbo and aftercooled) is not the worlds best starter. The one we had turned 185/hp only trouble we ever had was a steel hydralic line, and a fluke deal with the 2 speed (quad range).
WTW
02-15-2006 07:27:26
 Re: Am I crazy or what: 4630 JD in reply to JDBert, 02-15-2006 06:08:39
A 4630 has a much hevier transmission than the 4440. They may share some common part numbers in some areas/elements but by all means it is not the same transmission not even close. DW
JDBert
02-15-2006 08:11:34
 Re: Am I crazy or what: 4630 JD in reply to WTW, 02-15-2006 07:27:26
Not what I meant-I know the 4630 is a heavier built tractor (about ton). I was going for 8 speed to 8 speed with the ground speeds being pretty close.
Mike M
02-15-2006 04:53:00
Only concerns I see would be if the coolant has been changed as not to pit the liners. And do those have a 540 pto ? or maybe your baler is 1000 pto and it doesn't matter ?
ricedaddy
02-14-2006 21:34:34
with that low of hours, it sounds like a fair price for the HP, plus the 4630 was a tough tractor to say the least, cab, duals quick hitch? I had 2 that I put over 17,000 hours on and the biggest thing I can remember spending was for new tires!
Good luck, bring her home
Ron
JD 5020 guy
02-14-2006 21:17:26
If the tractor hasn't been abused I think that price is pretty fair. The 4630 is a 150 hp tractor. My neighbor paid over $58,000 for a JD 7800 with 5,000 hrs a few years ago. Sure its a lot newer then a 4630 but it only has 145 hp. Go to machinefinder.com and do a search for 4630s.
billyiron
02-14-2006 21:12:36
what year? if its a 76 or 77,,it wouldnt be to bad,,does it have the big rear axles?,,, billy
Mark Westphal
02-15-2006 13:16:16
 Re: Am I crazy or what: 4630 JD in reply to billyiron, 02-14-2006 21:12:36
It is a 1977. I do not know about the axles. I thought that they were all big axles on a 4630.
