4020 24volt wiring
tomboy
02-14-2006 18:48:44
need to no with wires go where on volage reg and gen 24 volt , there is white wire, black , brown, two brown wire together, blue and and white and red together, anyone no? this is 1968 tractor
buickanddeere
02-15-2006 16:24:11
 Re: 4020 24volt wiring in reply to tomboy, 02-14-2006 18:48:44
1-800-522-7448 and ask for SM-2029
WTW
02-15-2006 13:33:13
On the correct voltage regulator there will be four terminals: (BAT terminal gets Blue Wire from harness) (GEN terminal gets Red wire from tractor harness to regulator then goes to generator A1 terminal) (Field or F terminal gets Black wire to field terminal on generator) (A2 terminal at top of voltage regulator gets Brown wires Brown wire from tractor harness to regulator A2 terminal then goes to generator A2 terminal on bottom side of generator). God Luck, DW
R. John Johnson
02-15-2006 06:45:58
Try this site for the 4010
www.geocities.com/gwece/deere/
John
