'51 AR
JJ. in B.C.
02-13-2006 21:48:07
Hi Guys,
My '51 AR is getting harder and harder to get into gear (any gear). Sometimes i can't find any gears at all !! Does this sound like a major Trans. overhaul ?? What type of selectors do they have ? Any help appreciated.
JJ.
Glen in TX
02-15-2006 04:52:16
 Re: '51 AR in reply to JJ. in B.C., 02-13-2006 21:48:07
JJ, Yes the I&T is only going to be helpful on the engine and maybe some for the hydraulics and carb on the AR. I don't know of a service manual just for the AR or think they made one. The parts manual will help you a lot because you can see what parts are particular to the AR and what will also interchange from the A. If you need just a trans view for now from parts let me know. Usually your local JD dealer will have parts manuals that far back and can get you copy of just a page or two and they can order the parts manual also. There is a operators manual just for the styled AR also. They cover the AR hydraulics in the SM2011 manual, wiring diagram and electrics in the SM2029 and carb in SM2024. If you need more help later just post back and we will try here.
JJ. jn B.C.
02-14-2006 20:47:11
Hi Glen, Thanks for the response.
Looks like this is going to be a real learning experience !! I'm pretty "green" on JD's (if you'll excuse the pun). Haven't even figured out how to get inside the dern thing yet!! Have the I&T JD-4, pretty useless, try's to cover to many models as usual. The JD website should be a great help.
Thanks again JJ.
Glen in TX
02-14-2006 18:34:36
It could be one or several things causing it. The gearshift arm that fits on the end of shifter shaft could be worn or coming loose. It clamp fits on a taper on shaft end with a woodruff key and nut on end. If worn or loose it may just not engage the fork slots right. Forks could be bent or the one fork on 4th and 6th speed shifter shaft could be coming loose. Also the 3 springs and detent pawls in the forks could be worn, broke or binding. Also another seperate pawl and spring under a plug for 4th & 6th shifter. Probably just something simple in the shifter assembly. Parts catalog PC675 covers your styled AR and A & AO. The I&T JD-4 doesn't show anything for the AR trans and shifter.
