Buzzard Luck on 4020
toby
02-13-2006 16:07:35
Just got my 4020 overhauled and it started up and we broke it in as close as we could to recommendations. Has about 2 hours on it running sweet going down road and it starts to knock. What would be the best way to figure out the problem. Sounds like pistion hitting head. What should I check first.
Toby
WTW
02-14-2006 09:44:58
 Re: Buzzard Luck on 4020 in reply to toby, 02-13-2006 16:07:35
Good chance if you did not replace the rod bolts that one may have came loose or broke. Every time you torque a bolt it stretches and some bolt can take a second stretch and some won't. Deere recommends changing rod bolt every time on 30 series and later tractors. Problem is on older tractors this may be the second / third or who knows how many times the bolt has been reused and stretched each time. Drop the pan and see what you find. Good Luck, DW
ET
02-14-2006 05:13:46
Drop the oil pan and find out if a rod is loose. Don't run it until you do.
dp in nd
02-13-2006 18:23:04
Did you get yours rods checked for out of round, to big, to small, locol JD dealer had alot of trouble on overhauls before they started checking them.
toby
02-13-2006 16:44:59
The problem is we did it ourselves. This is not our first but never had this happen before.
Toby
430WLPG
02-13-2006 16:29:55
If you think the piston is hitting the head your problem is on the crankshaft,they may have left a rod cap loose, take it back, but don't run it any more
boll weevil
02-13-2006 16:15:12
I would carry it back to who ever overhauled it!
good luck: Ron
