Carb vs Governor
Gary U in CA
02-13-2006 15:53:12
720 Gas
Here�s my problem:
If I reduce the throttle at any rate than slow, the engine spools down to the setting as if was going to die. As it reaches this low throttle setting it aggressively adds fuel and a rapid increase in RPM occurs. Its so aggressive that you feel as if it will create an explosion out the exhaust � a fair amount of unburnt gas vapor emits as it revs up.
The carb is freshly overhauled by Roberts and I have set the linkage per the JD manual. I played with the throttle linkage hoping to allow the governor to coast the engine down to the setting � but it has little impact. The engine runs great otherwise and I find it hard to believe that this would be normal.
I appreciate your help
Gary
F-I-T
02-15-2006 07:24:31
 Re: Carb vs Governor in reply to Gary U in CA, 02-13-2006 15:53:12
Gary:
I�m not sure what the problem might be, but I�d like to hear the results of a few tests.
Remember, the governor is always trying to push the throttle plate in the carburetor closed, and the throttle spring is trying to pull it open. The point at which the spring tension of the throttle leaf spring pull and the governor weights push is in equilibrium is the position that the throttle plate will rest at. In normal operation, as the engine begins to slow down under load, the weights in the governor exert less force, the throttle spring pull is stronger than the governor push, so it moves the throttle plate open further until the engine speeds up to a position where the governor weights are again equal on force, At engine stop, there is no centrifugal force on the governor weights and any movement of the throttle lever will cause the throttle plate to open in the carburetor. Conversely, when you pull throttle back from a higher rpm position, the governor has almost total domination and pushes the throttle plate shut, sometimes with a quite a force. Usually you hope the idle position screw keeps the throttle plate from slapping shut and sticking. But it can. Now I think that the sudden burst of open throttle is being caused by the throttle place closing too far momentarily and getting stuck in the bore(s), one, the other, or both, or there is a linkage problem, so that while it is stuck closed, it stays there until the engine gets down to a point that is so substantially lower than the governor weight force that the throttle spring finally gets a huge dominance and is able to force the butterfly to come unstuck, and it gasps for life as it slams open from completely closed to wide open throttle. This explains why if you come down slowly the throttle plate is not pulled shut hard and it doesn�t have a chance to stick. That�s my theory.
So, what to do? I would unhook the throttle rod at the carburetor and close the throttle plate firmly by hand. Now as you try to open it, is it stuck or binding? If so, make sure your idle stop screw is set correctly. You should be able to set that engine running, no other linkage hooked up. Next, is the governor operating smoothly? Take the rod loose from the carburetor and hold the rod in your right hand while you move the throttle plate with your left. Does the engine always run smoothly? Does the governor push on the rod in an attempt to close the throttle plate?
If yes, put everything back together, and still examine that all of the linkages are smoothly operating. Like Mike said, look for catching cotter pins.
I think you will find your problem on the throttle plate closed position, but report back with a new thread so we�ll all see it when you post results.
Frank
Gary U in CA
02-15-2006 15:21:03
 Re: Carb vs Governor in reply to F-I-T, 02-15-2006 07:24:31
Frank
Great to hear from you, hope your doing well.
Sounds like a good plan, and your description sounds accurate. I will get some time with the tractor this weekend and will report back.
When are we going to hook up?
Thank you
Gary
F-I-T
02-15-2006 19:10:03
 Re: Carb vs Governor in reply to Gary U in CA, 02-15-2006 15:21:03
Oh, I just keep letting things get in the way. I was thinking about the other day that we need to figure out a time. My wife is coming out here the first weekend of April, so that would make a night on that Thursday (April 6th) that I could afford to have a real late night out. That would allow me to get to your house and back in the same evening, sleep in the next day and still pick my wife up around noon.
As far as you know now, are you gonna be in town that date?
Frank
toot
02-14-2006 10:47:36
Re-check linkage, check valve gap, check for vaccuum leak. When running close the choke a little and see it that smoothes it any.
Gary U in CA
02-15-2006 15:22:36
 Re: Carb vs Governor in reply to toot, 02-14-2006 10:47:36
Toot
I will give it a try this weekend.
Thank you
Gary
Dave NE IA
02-14-2006 06:24:56
I have alot of respect for Roberts, but they are only human. Even Roberts do make mess ups, check for the linkage binding then if thats not it unhook the linkage and try the hands on the carb. operation. Dave NE IA
Gary U in CA
02-15-2006 15:23:47
 Re: Carb vs Governor in reply to Dave NE IA, 02-14-2006 06:24:56
I will do so, thank you
Gary
wilamayb
02-14-2006 06:19:29
It sounds like a linkage problem from the gov to the carb. Like MikeM said check to make sure that they are not binding.
Gary U in CA
02-15-2006 15:25:06
 Re: Carb vs Governor in reply to wilamayb, 02-14-2006 06:19:29
Wilamayb
Thank you,
Gary
Mike M
02-14-2006 04:35:35
Is it possible that a cotter pin or too tight of a throttle shaft is binding up something in the linkage ?
How is it if you just operate the throttle at the carb. with your hand ?
Gary U in CA
02-15-2006 15:27:16
 Re: Carb vs Governor in reply to Mike M, 02-14-2006 04:35:35
Mike
Good to hear from you. I will investigate further this weekend. Good to hear from everyone that this is not the norm. This is the first gas powered Deere for me, so I do appreciate all the help.
Thanks,
Gary
