JD 50 6 or 12V pos. or neg. ground?
Jason D. Wahl
02-13-2006 13:38:30
Was the John Deere model 50 6 or 12 volt from the factory and was it still positive ground? I removed the original WICO XB distributor and temporarley put on a Wico X mag to get the owner running again. I got him a Delco dist. off of e-Bay already rebuilt but need to know what coil to buy for it and which way to wire it. Been awhile since this occured and do not remember what was what.
Paul_IN
02-13-2006 15:54:16
 Re: JD 50 6 or 12V pos. or neg. ground? in reply to Jason D. Wahl, 02-13-2006 13:38:30
The 12 volt system with positive ground is correct. It should be a 12 volt coil on the 50 to be totally correct to the original. The 6 volt coil and ignition resistor with bypass at cranking was not implemented until the LP gas tractors of the number series were introduced. Even then, it wasn't until the 20 series came out that JD put 6 volt coils with resistor on all spark ignition tractors.
55 50
02-13-2006 17:50:57
 Re: JD 50 6 or 12V pos. or neg. ground? in reply to Paul_IN, 02-13-2006 15:54:16
Paul,
My Parts Catalog (PC-264) shows ignition resistor available at S/N 5021480, LP first S/N as 5024000 so the resistor was on tractors prior to LP gas models.
Paul_IN
02-14-2006 14:35:19
 Re: JD 50 6 or 12V pos. or neg. ground? in reply to 55 50, 02-13-2006 17:50:57
You are right, I did not look in the book. Memory serves me wrong on this.
billde
02-13-2006 14:39:29
12 volt pos ground my 50 has a 12 volt coil pos wire to the dist. I can't say for sure but there is a possibility that it should be a 6 volt coil with a resistor.
