wheels and tires on a 46 B.
Ken Tabor
02-13-2006 12:36:54
I have cast wheels and wasn't paying much attention when I took the rims and tires off. Do the rims mount on the wheel from the front or the back. Can I put the wheel on the axle and then mount the rim, or does the wheel have to be slid over the axle and then backed onto the wheel. Does tha make sense?
Mike M
02-13-2006 12:42:45
 Re: wheels and tires on a 46 B. in reply to Ken Tabor, 02-13-2006 12:36:54
It also depends on which way your hub is facing.
They will go on and off without removing that cast center you just need to use the lower cutout spot and rotate the rim at like a 90* to the center and it will go.
