3010 engine overhaul
Dean Robertson
02-13-2006 11:33:20
Is it possible to pull heads, replace rings, bearings without removing the block, there seems to be plenty of room, I'm disabled so trying to make it as easy as possible, i was a aircraft mech, so do have some knowledge, any help would be apprecatied.
Thanks
DEan
msb
02-13-2006 20:49:04
 Re: 3010 engine overhaul in reply to Dean Robertson, 02-13-2006 11:33:20
If you are going to split the tractor to install the rear main seal then it only takes a few more bolts to pull the engine and put in an engine stand.That makes the job of removing the one head bolt under the scv valve,balancer block,replacing the front and rear seals and cleaning the o ring grooves a lot easier.Inspect the top o ring grooves very closely for pitting.Its pretty common on older tractors for the top grooves to be badly pitted.These pits can be repaired with a light coat of JB Weld.Being able to turn the engine upside down also makes it easier to inspect the oil pump drive gear on the camshaft.If the teeth are sharp then replace the camshaft and oil pump drive gear.I remove the cam followers and then power wash the inside of the block.Makes for a much cleaner job.There is a small hole in the side of,near the botton of the cam followers that a stiff wire can hook on to to lift the followers out of the block.Its a good idea to rebuild the water pump while its off and remove the oil cooler and at least replace the gaskets.Rod the cooler out if needed.
After meticulously cleaning the block and chasing all the head bolt holes,set the sleeves in place before installing the rods.Leave the o rings out at this point.The sleeves should set .001 to .004 above the top of the block.If your kit doesn't include instructions then don't remove the pistons from the sleeves.Push the pistons down just far enough to install the wrist pins.If a diesel engine,I strongly suggest you use both new rod bolts and especially recommend you use new head bolts. Torque the rod bolts to 100-110 ft# for a gasoline engine and 110-120 ft.# on a diesel John Deere o ring soap tends to dry out before the sleeves are installed.I add a little water to make the o rings stay slick a little longer.Dish washing soap works just as well.I like Ivory or Dawn? Once you get a sleeve in place, install a 9/16 bolt and flat washer to hold it in place until you are ready to replace the head.Sometimes the tightness of the new rings are enough to push the sleeve out of place when positioning the crankshaft for the next sleeve.
Timing the oil pump: Look down on the top of the oil pump drive gear with the oil filter o ring groove facing away from you.Position the vee mark so it faces toward the inside of the pump (toward the oil filter groove).Next follow the helically cut gear tooth on the back side (left) of the pump and line the bottom of the tooth with the center line of the pump shaft. With the engine crank on #1 TDC, install the pump. Install the balance block. Be sure to recheck to see the timing marks are right before installing the oil pan.
Borrow,beg or steal the proper rear seal installation tool.DO NOT remove the wear ring from the seal.The old wear ring can be easily removed with a crow foot after it has been stretched wth a couple cross wise licks with a hammer and cold chisel.(Not too deep).Also takes a special tool to push the front seal wear ring in place.I give both crank surfaces a very light coat of Permatex before installing the wear rings.Cut the excess gasket off and replace the oil pan.
At this point,I usuall reinstall the block in the rails.215 ft.lb-engine mount bolts.Then reinstall the head.Since EPA has mandated the removal of asbestos from head gaskets,it is a very good idea to use Copper Coat or alumunum paint on head gaskets. Very lightly oil the head bolt threads and install.The latest procedure is to tighten the very center bolt first(check that new manual first).Then the right side bolts from the rear to the front.Then tighten the remaining bolts in a circular pattern starting the center and working out.If the new head bolts are marked 180 or 12 something( I forgot)then torque them down to 150 ft.lbs(diesel only ,not sure about a gasloine).I go down to 135-140 first and the finish at 150.If done this way ,there is no need to retorque according to Deere engineers. Dealer techs should have a manual explaining the procedure. Gasoline valves intake-.015 exhaust .128.Diesel both .018. Flywheel is marked 10 degrees BTC,TDC and 180 degrees. For more information on timing ,tell us if it a diesel or gasoline engine and if diesel, the injection pump model.
Mike Bonham
05-22-2007 06:44:18
 Re: 3010 engine overhaul in reply to msb, 02-13-2006 20:49:04
I recently overhauled my john deere 3010, complete rebuild, however the rear main seal is leaking a little. I installed the "new" uni-type seal RE22764, using the proper tool from John Deere. I will admit that I removed the wear ring from the seal prior to installation, but thought that I put it back together correctly prior to installation. There are two grooves on the inner portion of the wear ring, and I installed these "towards the engine". Do these seals tend to seal up overtime, or am I eventually going to have to split it apart again, and replace. Thanks, Mike
dr=6800
02-14-2006 06:51:05
Thanks for all your information.
Dean
dr=6800
02-14-2006 06:50:22
Dean
Matt_In
02-13-2006 15:27:26
third party image
It will look something like this. My 3010 a few years ago.
dr=6800
02-14-2006 06:41:54
 Re: 3010 engine overhaul in reply to Matt_In , 02-13-2006 15:27:26
Thanks for your help.
Dean
Big 3010
02-13-2006 13:50:58
Mr. Dean, I have overhauled the engine in my 3010 diesel in the past year and to answer your question, yes there is plenty of room to do an in-frame engine overhaul in your tractor. Of course you will have to remove the hood, exhaust stack, air cleaner stack and the small panel between the hood and the dash. You will also find it necessary to remove the radiator, oil cooler, water pump, alternator/generator and belt(s). Be sure to drain the water from the water jacket in the block before removing sleeves. If your 3010 is a diesel then you will need to remove the injector pump,pressure lines and nozzles but you shouldn't need to completely remove the fuel return line going to the tank. It is extremely important to mark the timing of the injector pump both on the block and on the oil pump gear as this will save you future headaches (a bottle of white-out works well for this). You also need to remove the fuel filter housing and canisters. The cast iron oil pan is pretty heavy so don't get in a rush with it. I recommend using a floor jack with two 4x4 or 6x6 blocks which will provide a nice platform to let the oil pan down slowly and without much effort. After this, just remove the oil pump, oil pump screen, and remove all five main bearing caps to let the crank drop just enough in order to remove pressure from the rod bearings to facilitate their removal. When removing sleeves you should get a puller from a John deere dealer or where ever you can find one. You can tap the pistons out of the sleeves while still in the block once you have removed the oil pan and oil pump but be sure to remove the ring of carbon at the top of the sleeve so piston will slide out properly with out too much force. If you are re-using your old sleeves then they probably need to be miked to check if wear is within the tolerable limits. Be very careful not to chip the bottom lip of the sleeve during removal. Also when installing sleeves it is advisable to use new o-rings and a lubricating liner soap specifically for this purpose. The use of regular dishwashing liquid soap is not a good idea as it can rust crank journals if it drips on them. Liner soap is available at just about any john deere dealer. Have your head re-worked, resurfaced and pressure-checked before re-installation. Also have your injector nozzles/pump cleaned or rebuilt depending on what kind of shape they are in as bad nozzles and/or a bad pump can ruin a fresh engine. Plenty of floor-dry to soak up oil and water is a good idea too! John Deere offers a rebuild kit that includes new pistons, rings, sleeves, rod bearings, main bearings, front and rear main seals and all gaskets/o-rings, etc.. The sleeves supplied in this kit are 1/8in. larger in bore over stock and already have the pistons seated in them. This kit does require the re-use of your old rods and rod pins. Good luck with your rebuild and I hope that I was of some help to you.
dr=6800
02-14-2006 06:54:31
 Re: 3010 engine overhaul in reply to Big 3010, 02-13-2006 13:50:58
Thanks for all your great information.
Dean
WTW
02-13-2006 13:23:10
Dean You can do what us old John Deere mechanics refer to as a top and bottom overhaul. If there is no need to remove the crankshaft you can replace rings, sleeves and pistons, rod bearings and main bearings (if needed) in this tractor without splitting it. Change main bearings one at a time by rolling them in so weight of crankshaft is not applied to front and rear crank seals. It might not fly when you get done but I bet you can make it run real good. Good Luck, DW
dr=6800
02-14-2006 06:58:37
 Re: 3010 engine overhaul in reply to WTW, 02-13-2006 13:23:10
Dean
G/MAN
02-13-2006 13:22:42
Absolutely you can do an in-frame overhaul, providing the block doesn't need any repair. Removed the cylinder head, drop the pan (the oil-filter internal canister must come out of the pan before it will drop), roll in your new main bearings, slide in new pistons/sleeves, etc. Even if the rear main seal is leaking, all you have to do is split the tractor at the clutch housing, not remove the whole engine. Beg, borrow or steal a 3010 service manual and you'll have all the info you need.
dr=6800
02-14-2006 07:02:10
 Re: 3010 engine overhaul in reply to G/MAN, 02-13-2006 13:22:42
Dean
