6 or 12 Volt
Soldner
02-13-2006 08:01:16
I am currently working on a 49' JD A, and i pulled a 12 volt battery out of it, and when i looked at getting a new one, the book showed a 6 volt battery. Was it originally dual 6 volts, run in series to get 12 volts? If so, do i get a new 12 volt, or go back to dual 6's? Thanks everyone.
DickD
02-13-2006 13:01:03
 Re: 6 or 12 Volt in reply to Soldner, 02-13-2006 08:01:16
Soldner; Pay attention to what these guys are telling you. A year ago, I redid a 70, and since it was pretty nice, I put the 2 6 volt (Hi CCA) batteries in it. The tractor probably has been started 25 times. The other day I went out to start it, and one battery was done. Now it has one large, HI CCA battery in it, like I should have done to begin with.
John T
02-13-2006 08:45:16
Soldner, Im TOTALLY in Franks camp on this one and we usually?? agree lol.
Among the reasons I would use two sixes in series nowadays myslef, would be if pure originality or the Correct Police were of any concern, but they can "kiss my grits"
You still have to make an apples to apples comparison, i.e. a lil wimpy 12 volt will NOT store as much energy as the combination of two heavy duty sixes in series, while a super heavy duty modern single 12 (more often the case) will store MORE energy then two wimpy lil sixes. Lead Acid Batteries store energy with lead n acid n plates, so the more lead n acid n plates you stuff into the battery box, the more starting energy you store up. i.e a lil lawn more 12 volt battery sure aint gonna store more energy then two super sixes in series that completely fills the box Eh..... ... The disadvantage of two batteries is they should be of equal condition plus theres those extra connections that need to be considered.
If she MUST start at extreme cold temperatures and I used a single 12 volt battery, I would still use the heaviest highest rated battery I could find and at least 0 gauge cables Buttttt ttt (Frank loves that lol) I would go on to say that if my life depended on it, I may consider the use two of the 6 volt AGM Optima type batteries in series. I would have to take a close look at the ratings of the single 12 versus the series sixes if it were that critical.
Its Your tractor Your call
John T (Conservative Fuddy Duddy)
F-I-T
02-13-2006 08:21:06
The old "A"s had 12 volt systems, but back then the only way to get to a real hefty 12 volt battery was to use two 6 volters in series. Today, with the modern materials, you can generally find as big a CCA rated 12 volt battery as you need in a single unit. Besides, the six volters of today seem to have sort of a short shelf life and then they tend to ooze at the caps easily, unless you use and Optima gel-type battery which is my personal favorite.
Frank
Mike M
02-13-2006 09:19:33
 Re: 6 or 12 Volt in reply to F-I-T, 02-13-2006 08:21:06
Frank; I also totally agree about these 6 volt batteries oozing all over and the short shelf life.
Didn't you put an optima 6 volt in something of yours awhile back ? A case maybe ??? How is it doing ? I have not yet tried them.
F-I-T
02-13-2006 09:39:40
 Re: 6 or 12 Volt in reply to Mike M, 02-13-2006 09:19:33
third party image
I have installed three of the 6V's so far. One in my VAC Case, and one each on two 70 Diesels. So far, they have outstanding reserve power (one tractor isn;t charging all that well), and great cranking power. You can lay them on their side or hang them upside down without a worry about dripping or oozing. You can get 980 CCA out of a 6 volt battery and that is a ton of power. I know that there is no 100% transfer of energy, but if you got all 6KW output from this Optima to a starter, that is an instaneous 8hp.
It'll spin my Case 124 engine on a new overhaul with good compression like nothing is there.
They are kind of funny looking, though!
Frank
Stumpy
02-13-2006 15:18:41
 Re: 6 or 12 Volt in reply to F-I-T, 02-13-2006 09:39:40
Hey Frank,
If you don't mind, about how much did that Optima run you? Thanks
Stumpy
F-I-T
02-13-2006 15:46:27
 Re: 6 or 12 Volt in reply to Stumpy, 02-13-2006 15:18:41
Ummmm, I'd have to look, but probably the first one was right at $100 plus shipping, and the subsequent ones were probably $115. I have been using the first one for about two years now, and it seems to be holding up well. The true test will be if it lasts a good 2 to 2 1/2 times longer. Then it will be a good deal and a good performer.
Frank
