JD 50 Rad Flush
Larry Bro.
02-12-2006 17:40:17
I need to fulsh the Radiator in my JD50. The coolant is at least 5 years old and when drained I can see the tops of the tubes are partially blocked with a whitish gunk. I have heard of using a container of household IRON-OUT as a flushing agent. As follows: Drain and fill with water. Add one container of iron out. Run under light load for 8 hrs then drain flush with water and refill. Is this ok to do? Does it work well? Are there better alternatives? Thanks
F-I-T
02-12-2006 19:25:47
 Re: JD 50 Rad Flush in reply to Larry Bro., 02-12-2006 17:40:17
Larry:
There is a commercial product that we used to use to clean our commercial water softener zeolite resin beds that was called Iron Out. Sear's even sells it tiday as "Resin Bed Cleaner" in the plumbing department.
I'm guessing that this is not the same stuff, but maybe a household product that might be a little bit the same.
Anyway, if it is acidic in any way, you might want to use caution putting it in an older radiator core. I know I have used dilute Phosphoric Acid in a very rusty system becuase I had nothing to lose, and maybe this will be low enough strength to work but not do any damage.
I'd for sure read the label on a bottle before I poured it in.
Frank
