'68 4020 rear light and flasher
meatcutter
02-12-2006 12:17:45
From time to time my rear light flashes but the flasher on the fender just burns constant. Other times the rear light will not work at all, but the flasher works correctly. Do I have a ground problem or a signal stat problem or something else?
Jd40203020
02-12-2006 16:32:05
 Re: '68 4020 rear light and flasher in reply to meatcutter, 02-12-2006 12:17:45
Check your wires for a bare spot, or possibly a crossed connection between the flashers and back light. Could be crossed at connections on the fenders, or possibly the wires got switched on the switch. Could be bad grounds on the fenders or where the rear light swivels. If the flashers still give you fits, change the flasher bulbs(I have had these work sometimes and not the next) and with the engine off listen by the light switch for the flasher box "ticking". Its really hard to say, and could be a process to find a find for this problem. Do some checking and post back here, then we can help you more.
